Air filter for 2012 Sky Active
I have a 2012 Mazda 3 i Touring Skyactiv and I need to replace the air filter. I bought a Fram CA9898 but it did not fit. It had squared corners where mine are a little more rounded.
I found on another website that the following filters may be the correct: Purolator A44688, Wix 42612, Beck Arnley 042-1700, Mann MA 1113, Mahle LX 1688, ACDelco A3121C, and Hastings # AF1256 I did not see these brands at the local AutoZone. Is one of these the correct model? Who sells the brands? It is easy to change out, hate to pay a dealer to do it just because I can't find a replacement... - Jeff |
This is the one to put in. Never replace it, clean it, outflows all others:
https://www.mazdaforum.com/forum/int...-cx-5-a-31478/ |
You can check rock auto too. rockauto.com they got a lot of good deals on filters. Only thing is you will have to ship and wait for it to get there. I would get a K&N as well. That is what I am running, you just clean it every year and you are good for 1 million miles what they guarantee. Plus a little better gas mileage.
I work at an auto parts place myself and I looked up your car. The Wix number you found is for a 2012 mazda 3, but not the skyactiv. The wix number you're looking for is 49247 with the rounded edges. It's a little late but hopefully it'll help somebody later on. :)
Thanks for the reply. I did buy the K&N filter online and it did fit.
I did not notice a boost in gas mileage or power but I am just driving back and forth to work. The car gets good gas mileage though... ~37mpg a tank on mostly backroads which was what I was getting before the air filter. |
Originally Posted by JAC
(Post 145818)
K&N is a premium filter. |
(Post 145818)
I did not notice a boost in gas mileage or power but I am just driving back and forth to work. The car gets good gas mileage though... ~37mpg a tank on mostly backroads which was what I was getting before the air filter. If my assumption is right then Skyactive owners need to be cautious that they don't get a filter with lower flow rate. A friend of mine has a Moto Morini motorcycle. After changing the air filter he had trouble with the way the engine ran. Eventually, he exchanged the jets in the carburetors to smaller ones: the new filter was too restrictive. In fuel injected engines the computer will reduce the amount of fuel injected to achieve the same effect. |
JAC
I have the same car with the same problem. What kind of K&N air filter did you get. Thank you |
Originally Posted by stickyfingers
(Post 148131)
JAC
I have the same car with the same problem. What kind of K&N air filter did you get. Thank you There is a link to the proper K&N one. |
This is the one I got and it fit:
K&N 33-2480 High Performance Replacement Air Filter from Amazon.com |
