Air Bag Light on PROBLEM
Hi, there I'm new to this, so be pacient.
I have a Mazda3 2007, I got into and accident, on both driver side doors, no airbag deploid, but the seat belt on driver side got kind of stuck, so I replace it with a new one from dealer, but the ligth was still on, so I sent the SRS module to be reset, and when it came back I instaled it but the lith it's still on... any ideas....I don't want to go to the dealer, becouse they'll charge me $ 150.00 and hour, and they already told me that they need atlest 3 to only check my car. thanks |
RE: Air Bag Light on PROBLEM
Did you not have this fixed through your insurance?
That light is actually a code that should tell you exactly what is wrong. I'm not sure if you access that through the OBDII port under the steering column or not. Not the mention I don't see how a 2007 wouldn't still be under warranty. |
yeh the dealer cant charge you anything unless you have already driven over 60k miles in less than a year....and if u have than the airbag is the least of ur problems
