Aftermarket tail light replacement for leased Mazda 3
Old Sep 14, 2013 | 09:59 AM
Martiin's Avatar
Default Aftermarket tail light replacement for leased Mazda 3
My girlfriend has a leased Mazda 3. Someone broke her tail light and replacement is more than I would have thought. I found aftermarket tail lights such as the following on eBay at a much more reasonable price:
2010 2011 Mazda 3 Sedan 4 Door Non LED Passenger Right Tail Light Rear Lamp | eBay
Will replacing with an aftermarket part such as the one above cause any issues with returning the leased vehicle?
Old Sep 14, 2013 | 01:35 PM
RedGeminiPA's Avatar
Most aftermarket lights are close enough to OEM that I highly doubt a lease turn-in inspection would reveal it. Just make sure of the seller's return policy just in case it isn't as expected.
Old Sep 14, 2013 | 02:38 PM
Martiin's Avatar
Thanks for the info. Unfortunately I just found out that my girlfriend has the LED lights (sedan) which brings up the price quite a bit. If anyone knows of a source where I can save quite a bit from the dealer ($259), i would appreciate it.
Old Sep 15, 2013 | 08:12 AM
I just found this one. It looks to be the cheapest. Jump on it quick!
10 11 12 Mazda 3 RH Taillight LED Type | eBay
This is for a NEW aftermarket:
http://www.ebay.com/itm/Right-Passen...4a8bec&vxp=mtr
Old Sep 15, 2013 | 09:28 AM
Martiin's Avatar
I was able to pick up this one yesterday:
2010 2011 2012 2013 Mazda 3 Right Tail Light Nice | eBay
Hopefully the stress crack is as minor as claimed.
Do you know if any special tools are required to install or is installation pretty simple?
Old Sep 24, 2013 | 09:52 PM
jaimie08mazda3's Avatar
I don't know if the LED makes a difference when changing them but for my 08 it was pretty simple to remove the tails. 10MM deep socket and there are 3 of them on each side. Just be careful you don't break the clips that attach the carpet/plastic piece to the car. Use a flathead screw driver to take them out VERY carefully (coming from experience and I broke 5 of them.
PearlWhite5
Mar 8, 2013 09:24 AM
mecanolamb3rt
Aug 29, 2009 09:34 AM
graham
Aug 16, 2007 11:53 AM
vvbunglevv
May 25, 2006 12:06 PM
the_gray_mazda6
Nov 30, 2005 12:36 AM
