AC Fan Issue
The air conditioner is cold as balls so that's fine.
Problem is just a couple of days ago my fan hasn't been blowing at full speed... unless I make a left turn (weird). And only a left turn. Not when I turn the wheel left either. That does nothing. Only if I make a left turn driving the car, not sitting idle. After the turn it goes back to the slower speed. My guess is something may be loose under the hood like an electrical connection or something and momentum from the left turn is kinda "forcing" whatever it is back into place for a quick second. |
EDIT: All of a sudden went back to normal this morning. lol
Could it be that something got "moved" when you installed your stereo system, Gary? that the problem is actually in the dash? Just cause it went away today does not mean it won't be back tomorrow. |
Originally Posted by virgin1
(Post 96313)
Could it be that something got "moved" when you installed your stereo system, Gary? that the problem is actually in the dash? Just cause it went away today does not mean it won't be back tomorrow. im observing that the problem happens when it's hot out... when it's cooler it blows at full blast. and i thought about if i was just imagining that since it is hotter out and could give that possible effect and trick me... but no. when it's hot, it does blow harder on left turns like mentioned. when it's cooler, it blows just as hard no matter if im turning left or not. and if it was something stereo related, I would guess this could have happened earlier than it did. the factory radio wasnt in that car very long. I'm at around 41.5k miles on the odometer. I installed the radio somewhere in the range of 2k or 3k to about 5k or 6k is my guess. Lots of miles in that time... and about a year time frame. |
aye i figured out what it's doing, but dont know the fix...
the blower is fine. it wont switch between vent and floor combo, and vent only. if i go to vent only, it stays at floor and vent combo. it'll go to all the other options, and go back to vent/floor, but wont go to vent only at all. weird |
Try looking for the online workshop manual.
See this: NO.1 INSUFFICIENT AIR (OR NO AIR) BLOWN FROM VENTS -------------------------------------------------------------------------------- B3E070301038W03 1 Insufficient air (or no air) blown from vents DESCRIPTION • Problem with each vent and/or duct. POSSIBLE CAUSE • Malfunction in VENT mode system (Steps 1-4) • Malfunction in HEAT mode system (Step 5) • Malfunction in DEFROSTER mode system (Steps 6-8) Diagnostic procedure STEP INSPECTION ACTION 1 INSPECT TO SEE WHETHER MALFUNCTION IS IN VENT MODE OR OTHER MODES • Does air blow out when in the VENT mode? Yes Go to Step 4. No Go to the next step. 2 INSPECT VENT • Is the vent clogged? Yes Remove obstruction, then go to Step 8. No Go to the next step. 3 VERIFY THAT DUCT IN DASHBOARD IS INSTALLED • Is the duct in the dashboard properly installed? Yes Inspect the duct for clogging, deformation and air leakage, then go to Step 8. No Install the duct securely in the proper position, then go to Step 8. 4 INSPECT TO SEE WHETHER MALFUNCTION IS IN HEAT MODE OR DEFROSTER MODE • Does air blow out when in the HEAT mode? Yes Go to the next step. No Inspect the vent for clogging, then go to Step 8. 5 INSPECT DEFROSTER MODE • Does air blow out when in the DEFROSTER mode? Yes Operation is normal. Recheck malfunction symptoms. No Go to the next step. 6 INSPECT VENT • Is the vent clogged? Yes Remove obstruction, then go to Step 8. No Go to the next step. 7 VERIFY THAT DEFROSTER DUCT IS INSTALLED • Is the defroster duct properly installed? Yes Inspect the duct for clogging, deformation, and air leakage, then go to the next step. No Install the duct securely in proper position, then go to the next step. 8 CONFIRM THAT MALFUNCTION SYMPTOM DOES NOT RECUR AFTER REPAIR • Does air blow out? Yes Troubleshooting completed. Explain repairs to customer. No Recheck malfunction symptoms, then repeat from Step 1 if the malfunction recurs. |
Here is the link:
http://www.ozmazdaclub.com/manuals/m...ual/index.html Everything you ever wanted to know about your m3 |
thanks! I'll take a look
| All times are GMT -5. The time now is 08:00 AM. |
