-   Mazda3 (https://www.mazdaforum.com/forum/mazda3-26/)
-   -   2015 Mazda 3 ECU for Singapore Model (https://www.mazdaforum.com/forum/mazda3-26/2015-mazda-3-ecu-singapore-model-49185/)
unclechav Mar 2, 2022 04:37 PM
Hi All,
I am seeking an ECU for my Mazda 3 (image below), which has been stressful.
https://cimg0.ibsrv.net/gimg/www.maz...9aeeea328b.jpg
A question:
1. Do both numbers have to match i.e. PELS-18- ... & P5BG 18- ... when searching online for one to match my car?
Thanks in advance
dinellorm Feb 21, 2023 06:47 PM
Im searching for this part also. Can you confirm if you found it
Originally Posted by unclechav (Post 202683)
Hi All,
A question:
Thanks in advance
I'm searching for this part also. Can you confirm if you found it
unclechav Feb 22, 2023 06:22 AM
I didn't. I had to order a new one straight from the manufacturers in Japan. My mechanic is currently in the process of reprogramming the new ECU as we speak.
Hope this helps.
dinellorm Feb 23, 2023 06:15 PM
Follow up
Hope this helps.
Did all 3 sets of numbers match on the new box? PELS etc
unclechav Feb 23, 2023 06:51 PM
Nope. So what was different was there was an 'A' at the end. So, it read PELS-18-881A.
It was reprogrammed successfully, he is now trying to program the key to the ECU.
Callisto Feb 24, 2023 10:09 AM
Universal information that will pertain to not only Mazda but most all different makes and model vehicles.
A refurbished or another term rebuilt ECU will generally not match factory numbers. The rebuilder will do a pass-through or what is also called ECU flash with the most currently available or last ECU update from the auto manufacture.
There are dozens of ECU/PCM/TCM business mostly in the USA that offer them. For harder to find units they may have a core charge for the return of your old unit.
OEM number will often be superseded by the auto manufacture. You must contact a dealership parts department and have them see if there were any revisions to an existing part number on any part you are seeking.
Karstenimports Jun 20, 2023 02:03 AM
Hi kindly advice me on how you got the ecu for Mazda 3 did the lower number P5BG 18 8K2B match.am looking for similar ecu for my Mazda 3
Dave2129 Aug 6, 2024 08:30 PM
Hi All,
A question:
Thanks in advance
Hi good day. Can you provide any info on obtaining an ECU like this? Or the number on the one you ordered please. I need to get one
Callisto Aug 6, 2024 11:30 PM
Hmmm I just posted in another thread same info which I would post for you. I suggest go read it.. :rolleyes:
Also did you even read what I posted in this thread?:rolleyes:
