2009 mazda 3 cruise control
I'm having some problems installing a aftermarket cruise control in my 09 mazda 3, if anyone has any knowlage\experance with Rostra cruise kits, I would greatly apperaciate the info.
Link to cruise kit Custom Drive-By-Wire Cruise Aftermarket Cruise Control by Rostra
scroll down to model 250-9009
Where are you located? If your 3 has drive by wire throttle (most major countries have this) then you can add the OEM cruise by replacing two parts in your car. All you need is a replacement brake switch, and replacement steering wheel controls with the cruise switches. IIRC if bought new they run around $200 for both parts, but you can probably find the parts used from a junk yard or ebay, etc.
Thanks for the reply but I took a second look at the instructions and realized I'm an idiot
Btw the kit cost about $140 and took around 2 hours to put in. The only downside is the controls are on the steering column instead of the wheel
Just get the OEM parts and you'll be good to go.
