2007 Mazda 3 Lt headlamp issues
Old Aug 23, 2019 | 03:19 PM
Slidchickenleg's Avatar
Default 2007 Mazda 3 Lt headlamp issues
have a 2007 Mazda 3, the left headlamp bulb was burnt out as well as the socket. I replaced both socket and headlamp bulb but still nothing. The right side low beam works jut fine. Ive checked both the fuse and relay there is power getting to them but no power to left headlamp socket... any suggestions ??
Old Aug 25, 2019 | 06:24 AM
There will be individual fuses for each headlamp
Old Aug 25, 2019 | 08:50 AM
Both fuses were good… Looks like I have 12 V that run in to the fuse box under the hood and then it shows a dead wire coming out of the fuse box. So it looks like my problem may lie in the fuse box under the hood
Old Aug 26, 2019 | 06:12 AM
There should be four headlamp fuses, LH Low Beam, LH High Beam, RH Low Beam, RH High Beam.
Have you tried measuring voltage at the headlight plug?
Old Aug 26, 2019 | 08:06 AM
I get nothing at the left headlamp socket… But I do get 12 V right before the fuse box under the hood
t2000kw
Oct 14, 2017 09:00 AM
Elethim
Mar 11, 2014 10:15 PM
makmazda
Apr 21, 2012 08:09 AM
alsnchns
Oct 17, 2008 04:28 AM
mazdafan
Apr 29, 2006 02:35 PM
