2004 mazda 3- no spark at spark plug coils replaced both the cam and crank sensors.
coil pack only had one spark and stopped so i replaced the cam and crank sensor still same issue checked power to connectors to coil pack and i have 12 volts. where to now im stuck.
Why did it stop running? What else has been done to the car?
Check for fault codes. On initial cranking all coils and injectors fire simultaneously, as the ECU doesn't know where the pistons are. |
| All times are GMT -5. The time now is 03:23 AM. |
