05 2.3L not running
Old Sep 17, 2018 | 11:08 AM
tig7633's Avatar
Default 05 2.3L not running
Need a little help guys. My step daughter was driving home after getting fuel, and about a half a mile down the road it died in a turn lane. Initial symptoms lead to a bad fuel pump, but not wanting to throw parts at it, I started checking voltages. the pump was not getting power, but the level sending unit is. Tried spraying starter fluid in intake, car started up. Put code reader on it and got 22 codes:
0102, 0403, 0443, 0758, 0763, 0768, 0773, 2009, 2088, 2101, 2128
Pulled battery cables cleaned all grounds, but still no power to fuel pump relay solenoid coil. Jumped power for pump at relay, pump energizes, but car will not start. Got 50psi on rail when first gave it power. I have been unable to find any power schematics from key switch, or fuel circuit. The car has also had the common parking light not coming on, nad you have to tap the glove box for them to come on.
topol
Dec 6, 2015 11:32 AM
STSKyle
Aug 31, 2014 04:34 AM
nouse4aname067
Mar 9, 2008 10:47 AM
93_26004x4
Jul 4, 2006 12:24 PM
