Passenger window
Hi guys!
I have a 2013 mazda 2 that I picked up a few months ago. The passenger side power window hasn't worked since I bought the car and I'm digging into it a little. For reference, the car has manual windows in the back so it's just the front that are powered. The drivers side works absolutely fine. I've tried the switches either side of the car and neither of them operate the window. When the buttons are pressed there is a distinct click from inside the passenger door (sounds like a relay click?) Are there any real obvious things to check before taking panels off etc? Obviously the window lock is NOT on as I cna operate the other side. I'll go check the fuse today but from my reading, if it was the fuse then the drivers side would also not work? I own a multimeter to be abled to test electrics but if I'm honest, I've no idea how it works so if that's the path to take then I'll do some further learning on the multimeter itself hah! |
