Mazda Verisa/Mazda 2
Old Nov 24, 2009 | 03:04 PM
Mukabi1's Avatar
where are the following sensors located in a mazda 2
1. MAF sensor
2. engine speed sensor
3. wheel speed sensor
Old Nov 27, 2009 | 03:08 PM
Mukabi1's Avatar
Default Shift shock
Hi People,
My Mazda is experiencing a shift shock as it changes fro gear 2 to gear three or from gear three to four. What cud be the problem. It jacks forward when it is changing the gears
Old Nov 27, 2009 | 06:31 PM
Dude!! Are you for real?? You're scaring me.
At first I thought you might just be a guy with a question or two, or a problem. Now you're coming up with all sorts of things.
It seems that everyday you've got something new to add. Maybe, its the owner more than the car?
Old Nov 28, 2009 | 03:10 PM
Mukabi1's Avatar
What causes a shift shock in Mazda. The car jacks forward when automatically changing gears
Old Nov 29, 2009 | 02:18 PM
If its shifting hard, the computer that decides where and how the transmission shifts if likely the answer.
Dealer inquiry required here.
Old Nov 30, 2009 | 10:58 AM
Mukabi1's Avatar
Thank you!!!
Old Jan 25, 2010 | 01:44 PM
Mukabi1's Avatar
Default Error code P0715
Does a faulty Input/Turbine Speed sensor cause the car to shift hard btween gear 1, 2 and 3?
Old Jan 25, 2010 | 03:31 PM
No. The software in the trans computer makes it shift hard.
They may do that because the 2 is inherently slow and underpowered. A faster shift helps make up for that, or at least gives the illusion that the car is faster than it is.
The 2 is certainly a better driving car w/the manual trans.
Old Aug 28, 2012 | 10:28 AM
Ikedzinza's Avatar
Exclamation Check engine illumination on my dashboard
Please guys can you help me. I have a 2004 Sports Mazda Verisa and recently i have noticed that it has been showing me the Check Engine Illumination light on my dashboard. Firstly it used to come up and go for weeks then yesterday it has shown up and is still showing up today. What could be the cause to this. Please help i ma worried this may cause my engine to seize.
Old May 3, 2021 | 01:06 PM
akariz's Avatar
1. MAF sensor
check out this YouTube video, it shows how to clean both MAF & Throttle.
youtu.be/KyelnxG7bMY
