Mazda low biting point
Old Apr 8, 2024 | 11:43 AM
Spamnator's Avatar
Default Mazda low biting point
Hi guys, new here.
Recently got a Mazda 2 2012 and the car drives great, no issues however the issue i have is that the biting point is low when starting the car. So when i go into gear 1, i find it very hard to find the biting point and end up stalling, once i get past gear 1, it drives fine and no issue with the clutch, Is this normal or do i need to do something?
Old Jun 18, 2024 | 05:26 PM
Smoose91's Avatar
Originally Posted by Spamnator
Hi guys, new here.
Hi there! Hopefully you've already sorted the issue but if not try the following:
On a flat, quiet road with no cars around, put the car into first gear and lift the clutch without accelerating. The car should stall. Try it in second also. If the car does not stall, you need a new clutch. If it does but it takes until the highest point of the clutch, you're very close to needing a new clutch, which is what I suspect this is.
Old Aug 31, 2024 | 06:52 AM
CTofW's Avatar
I had my clutch changed last week. New to Mazda so asked about adjusting it but was told apparently there is no adjustment due to it being a hydraulic clutch. Getting used to the biting point being just off the carpet now....
MKMGRAND
Mar 24, 2023 06:16 AM
Meandmyz
Jan 21, 2023 11:54 AM
Hemp6473
Apr 22, 2021 04:14 PM
SledDawg
Jul 23, 2018 10:04 AM
furtula
Dec 20, 2016 12:50 PM
