Mazda 2 washer problem
Old Aug 17, 2024 | 04:49 AM
hangman960's Avatar
Default Mazda 2 washer problem
Mazda 2 Hardly any water comes out of windscreen washers doesnt touch the screen,i can hear the pump working and its fine on the rear windscreen.
Ive blown air through both washer squirters and it blows air out.
Any ideas? im stumped
Old Aug 18, 2024 | 05:44 PM
Muted's Avatar
Hello, hangman960.
Here's an online manual reference that might help:
- wiper_washer_system-1277.html
I'd suggest testing the motor itself for failure; if there's a leak somewhere causing inadequate pressure: You might try using soapy water and an air compressor of some sort; you should be able to see the bubbles form as they exit the cracked areas or perhaps use distilled water and a bright food dye such as red that's easily identifiable and follow the pipelines to see if you can find a leak.
Old Nov 3, 2024 | 06:04 AM
hangman960's Avatar
Default Washer cover removal and washer nozzle removal
How do i remove these?
I have a pipe i need to replace on drivers side and want to replace nozzle aswell how do i get the cover up and remove and replace nozzle
please
cncman40
May 26, 2020 12:37 PM
peterc4
Aug 17, 2016 02:42 PM
Hoosier56
Feb 6, 2013 03:03 PM
keenan
Mar 26, 2009 06:48 PM
Wonger
Nov 22, 2007 06:37 PM
