Mazda 2 DE 1.5lt OBD2 PIDs - Before & After Throttle Body Cleaning
Old Feb 10, 2024 | 08:22 PM
OZCorolla_x2's Avatar
Default Mazda 2 DE 1.5lt OBD2 PIDs - Before & After Throttle Body Cleaning
Picked up a 2009 Mazda 2 1.5lt
Doing all Fluids & General Maintenance so I get a Benchmark.
Full Op Temp Idle TP was 12.2%
=>> This is too High, Dirty Throttle Body, Dirty MAF & Dirty IAT
MAZDA 2 Standard OBD2 PIDs:
2024_01_28: 171,065km
** BEFORE Throttle Body plus IAT & MAF Cleaning **
Before Cold Start: OBD2 Flyby Wire Throttle Body
JDIAG 906S
[1] DTC_CTN: 0
[2] FUEL SYSA: OL-Drive
[3] FUEL SYSB: —
[4] LOAD_PTC(%): 0.0
[5] ECT (Deg C): 29
[6] SHRTFT1(%): 0.0
[7] LONGFT1(%): -9.4
[8] MAP(kPa): 102.0
[9] RPM: 0
[10] VSS(km/H): 0
[11] SPARKADV(Deg C): 6.0
[12] IAT(Deg C): 30
[13} MAF(g/s): 0.00
[14] TP(%): 22.7
[15] O2SLOC B1S12: - - B2S - - - -
[16] O2B1S2(V): 0.000
[17] SHRTFTB1S2(%): 99.2
[18] OBDSUP: EAOBD
[19] RunTM(SEC): 0
[20] MIL_DIST(km): 0
[21] EGR_PTC(%): 0.0
[22] EVAP_PCT(%): 0.0
[23] WARM_UPS: 6
[24] CLR_DIST(km): 277
[25] EQ_RATB1S1: 0.999
[26] O2S11(mA): 0.000
[27] CAT_TEMP11(Deg C): 29.4
[28] VPWR(V): 12.376
[29] LOAD_ABS(%): 0.0
[30] EQ_RAT: 0.999
[31] TP_R(%): 13.3
[32] TP_B(%): 22.7
[33] TP_D(%): 31.8
[34] TP_E(%): 20.8
[35] TAC_PCT(%): 16.5
** Before Throttle Body, IAT & MAF Cleaning **
Before Cold Start: Foot to the Floor: OBD2 Flyby Wire Throttle Body
[14] TP(%) Foot to Floor: 90.2%
[31] TP_R(%) Foot to Floor: 81.2
[32] TP_B(%) Foot to Floor: 90.6
[33] TP_D(%) Foot to Floor: 78.0
[34] TP_E(%) Foot to Floor: 66.7
[35] TAC_PCT(%): 100.0
2024_01_29: 171,191km
** FULL OP TEMP IDLE, All Accessories Off, Neutral **
Noted: ma2auto.com/engine_tune_up-1077
JDIAG 906S
[1] DTC_CTN: 0
[2] FUEL SYSA: CL
[3] FUEL SYSB: —
[4] LOAD_PTC(%): 23.5
[5] ECT (Deg C): 94
[6] SHRTFT1(%): 0.8
[7] LONGFT1(%): -10.9
[8] MAP(kPa): 30.0
[9] RPM: 648
[10] VSS(km/H): 0
[11] SPARKADV(Deg C): 8.0
[12] IAT(Deg C): 38
[13} MAF(g/s): 1.54
[14] TP(%): 12.2
[16] O2B1S2(V): 0.885
[18] OBDSUP: EAOBD
[19] RunTM(SEC): 1739
[22] EVAP_PCT(%): 10.6
[23] WARM_UPS: 10
[24] CLR_DIST(km): 401
[25] EQ_RATB1S1: 1.002
[26] O2S11(mA): 0.008
[27] CAT_TEMP11(Deg C): 437.2
[28] VPWR(V): 13.791
[29] LOAD_ABS(%): 16.9
[30] EQ_RAT: 1.004
[31] TP_R(%): 3.1
[32] TP_B(%): 12.5
[33] TP_D(%): 31.8
[34] TP_E(%): 20.4
[35] TAC_PCT(%): 3.9
2024_01_20: 171,245km
** THROTTLE BODY CLEANING plus IAT & MAF CLEANING
2024_02_03: 171,530km
** 285km After Throttle Body, IAT & MAF Cleaning **
JDIAG 906S
[1] DTC_CTN: 0
[3] FUEL SYSB: —
[5] ECT (Deg C): 23 Deg C
[6] SHRTFT1(%): 0.0
[7] LONGFT1(%): -6.3
[8] MAP(kPa): 102.0
[9] RPM: 0
[10] VSS(km/H): 0
[12] IAT(Deg C): 27
[13} MAF(g/s): 0.00
[14] TP(%): 22.4
[18] OBDSUP: EAOBD
[19] RunTM(SEC): 0
[23] WARM_UPS: 8
[24] CLR_DIST(km): 332
[27] CAT_TEMP11(Deg C): 23.12
[28] VPWR(V): 12.239
[30] EQ_RAT: 0.999
[31] TP_R(%): 13.3
[32] TP_B(%): 22.7
[33] TP_D(%): 31.8
[34] TP_E(%): 20.8
2024_02_10: 171,751km
** 506km AFTER THROTTLE BODY CLEANING plus IAT & MAF CLEANING **
JDIAG 906S
[1] DTC_CTN: 0
[2] FUEL SYSA: CL
[3] FUEL SYSB: —
[4] LOAD_PTC(%): 22.4
[5] ECT (Deg C): 92 to 100 Deg C. Fans run for 30 Seconds drops back to 92 Deg C
[6] SHRTFT1(%): 0.8
[7] LONGFT1(%): -7.8
[8] MAP(kPa): 30.0
[9] RPM: 650
[10] VSS(km/H): 0
[11] SPARKADV(Deg C): 7.0
[12] IAT(Deg C): 34
[13] MAF(g/s): 1.50
[14] TP(%): 10.6
[Was 12.2 before Throttle Body Clean]
[16] O2B1S2(V): 0.915
[18] OBDSUP: EAOBD
[19] RunTM(SEC): 2208
[23] WARM_UPS: 23
[24] CLR_DIST(km): 549
[26] O2S11(mA): - 0.004
[27] CAT_TEMP11(Deg C): 452.2
[28] VPWR(V): 13.876
[30] EQ_RAT: 0.998
[31] TP_R(%): 1.6
[32] TP_B(%): 11.0
[33] TP_D(%): 31.8
[34] TP_E(%): 20.4
[35] TAC_PCT(%): 2.0
What are others seeing Before & After THROTTLE BODY CLEANING plus IAT & MAF CLEANING ?
Rob
Old Feb 11, 2024 | 10:10 AM
Got a new toy to read the ECU did ya?
There are actually over 105 PIDS for an average Maza. Not sure why you are posting this 99% of members do not even understand most of this information let alone be able to read the variables and interpret its meaning.
BTW if you did a proper throttle body cleaning unless you had a specific and verified DTC relating to the operation of the Throttle body NOTHING should have changed except improve MPG and maybe off idle throttle response! Then you would see that only 2 of the PIDs!
Old Feb 11, 2024 | 03:16 PM
The New Toy is the MAZDA 2, lots of fun to be had. Have been OBD2 since 2006 & OB1 before that, wrenching is fun.
Re: "105 PIDS for an average Maza"
I've just posted what the two common readers show for Live Data Stream on "Drivetrain" to show the difference between OBD2 & JOBD2. There are more PIDs available for the BCM & DCS etc so the number accessible is greater than 105
Re: "Not sure why you are posting this 99% of members do not even understand most of this information"
Provides a benchmark for others if they are running 91RON non ethanol ULP & at 10m to 20m AHD & they can also identify the outcome of the throttle body cleaning.
OBD2 has been standard for all new cars since nominal 2006 so there has been time to get to grips with OBD2......Was surprised a similar post was not on the Mazda2 Forum given the age of these cars. Gunking of Throttle Body, EGR & PCV etc considerably dependent on weight of Oil & NOACK of the oil used in the car. They need a clean.
WRT "NOTHING should have changed except improve MPG and maybe off idle throttle response"
Noted Throttle Body Plus IAT & MAF cleaning were done.
=>> I'll disagree. As expected, have seen the TP% Change, MAF & LTFT after nominal 300kms of additional driving "as the Fuel Trim Mapping Re Learns the New Normal operating conditions". The Idle quality has also stabilised to a rock solid 650RPM. If it does not then Inlet Manifold Gasket, vacuum leak or EGR are the next steps. WRT Fuel Economy change, wil see what happens over the next 5,000 to 10,000kms.
Re "Then you would see that only 2 of the PIDs!"
Not quite....my thoughts are see the PIDs in Bold as the Focus/Items to watch as the effects of the Throttle Body Plus IAT & MAF cleaning re Map the LTFT Table in the ECU.
Qu:
What is the TP% on your MAZDA 2 1.5lt DE at FULL OP TEMP IDLE, All Accessories Off, Neutral, Foot not on Brake?
Rob
Old Feb 11, 2024 | 10:05 PM
Qu:
Rob
I am sure that if you look around this forum you will find several posting operational pictures with selected PID I choose to watch more then others on every drive! And there is your answer in a few pictures aw well.
My Mazda is a 2018 2.5 automative touring , but if you read my signature it is not exactly what Mazda claimed it to be anymore
Old Feb 12, 2024 | 10:02 AM
I should have mentioned while somewhere you categorized me as a DIY that fine not exactly even close my Throttle body I currently run on my Mazda is my own Machined sizing custom plate, throttle shaft as well fasteners and other proprietary modifications. So while it is not only slightly larger in mm it is also flowed better then OE and for that matter most all the currently available "performance" TB available in the aftermarket. So my TB% is not factory and adjusted in the TB actuators as well the ECU programing for the modification to that throttle body.
Old Feb 12, 2024 | 03:05 PM
I can see you enjoy a discussion Callisto.
Its a no Bait policy.
Per: mazdaforum.com/forum/mazda2-53/mazda-2-de-1-5lt-obd2-pids-53403/
Re: "On some forums we actually have a couple of educated and trained and experienced Service technicians."
If that is the case & you are one of those, pleased to meet you. I am sure we will get on well as the DIY section expands.
Rob
Old Feb 12, 2024 | 05:40 PM
Rob
Ok I need a little time to get use to your use of the English language. Sorry !
To answer you quarry 15.3%
Old Mar 29, 2024 | 03:24 AM
** 4700km since Throttle Body, IAT & MAF Cleaning **
Review of OBDII PIDs
91RON Non Ethanol
2024_03_29: 175,944km
** 4700km sinceThrottle Body, IAT & MAF Cleaning **
Before Cold Start:
JDIAG 906S
[1] DTC_CTN: 0
[3] FUEL SYSB: —
[5] ECT (Deg C): 22 Deg C
[6] SHRTFT1(%): 0.0
[7] LONGFT1(%): -5.5
[8] MAP(kPa): 103.0
[9] RPM: 0
[10] VSS(km/H): 0
[12] IAT(Deg C): 24
[13} MAF(g/s): 0.00
[14] TP(%): 22.7
[18] OBDSUP: EAOBD
[19] RunTM(SEC): 0
[23] WARM_UPS: 213
[24] CLR_DIST(km): 4381
[27] CAT_TEMP11(Deg C): 23.3
[28] VPWR(V): 12.213
[30] EQ_RAT: 0.999
[31] TP_R(%): 13.3
[32] TP_B(%): 22.7
[33] TP_D(%): 31.8
[34] TP_E(%): 20.8
Engine Off
Accelerator Pedal at WOT ie Foot to Floor:
[7] LONGFT1(%): -3.1
[14] TP(%): 90.2
[31] TP_R(%): 81.2
[32] TP_B(%): 90.6
[33] TP_D(%): 78.0
[34] TP_E(%): 67.1
Take it for a mixed 80km/Hr run then check Full Op Temp Idle PIDs
2024_03_29: 175,974km
** 4,729km since THROTTLE BODY CLEANING plus IAT & MAF CLEANING **
JDIAG 906S
[1] DTC_CTN: 0
[2] FUEL SYSA: CL
[3] FUEL SYSB: —
[4] LOAD_PTC(%): 22.7
[5] ECT (Deg C): 97, Cycles from 92 to 100 Deg C. Fans run for 30 Seconds drops back to 92 Deg C
[6] SHRTFT1(%): 0.0
[7] LONGFT1(%): -10.2
[8] MAP(kPa): 30.0
[9] RPM: 664
[10] VSS(km/H): 0
[11] SPARKADV(Deg C): 5.0
[12] IAT(Deg C): 36
[13] MAF(g/s): 1.50
[14] TP(%): 10.6
[18] OBDSUP: EAOBD
[19] RunTM(SEC): 2043
[23] WARM_UPS: 213
[24] CLR_DIST(km): 4407
[25] EQ_RATB1S1: 0.994
[26] O2S11(mA): - 0.020
[27] CAT_TEMP11(Deg C): 416
[28] VPWR(V): 13.841
[29] LOAD_ABS(%): 16.1
[30] EQ_RAT: 1.004
[31] TP_R(%): 1.6
[32] TP_B(%): 11.0
[33] TP_D(%): 31.8
[34] TP_E(%): 20.4
[1] DTC_CTN: 0
[2] FUEL SYSA: CL
[3] FUEL SYSB: —
[4] LOAD_PTC(%): 27.8
[5] ECT (Deg C): 100, Cycles from 92 to 100 Deg C. Fans run for 30 Seconds drops back to 92 Deg C
[6] SHRTFT1(%): -2.3
[7] LONGFT1(%): -8.6
[1] DTC_CTN: 0
[2] FUEL SYSA: CL
[3] FUEL SYSB: —
[5] ECT (Deg C): 92, Cycles from 92 to 100 Deg C. Fans run for 30 Seconds drops back to 92 Deg C
[7] LONGFT1(%): -7.0
The Mazda 2 runs hot compared to a Corolla.
25.1 Deg C Ambient
62% RH
Non Contact Thermometer to check the OBDII ECT PID
Top Hose of Radiator 81.5 Deg C to 85.5 Deg C
Top Tank of Radiator 88.0 Deg C Up to 97 Deg C - That is a lot of thermal stress for a polymer radiator Top Tank
Rob
Old Mar 29, 2024 | 09:40 AM
You forgot a step...
Old Nov 22, 2024 | 07:07 AM
Smile
** 13,958km since Throttle Body, IAT & MAF Cleaning **
91RON Non Ethanol
2024_11_11: 184,978km
Before Cold Start:
JDIAG 906S
[1] DTC_CTN: 0
[3] FUEL SYSB: —
[5] ECT (Deg C): 28 Deg C
[6] SHRTFT1(%): 0.0
[8] MAP(kPa): 102.0
[9] RPM: 0
[10] VSS(km/H): 0
[12] IAT(Deg C): 29
[13} MAF(g/s): 0.00
[14] TP(%): 22.7
[18] OBDSUP: EAOBD
[19] RunTM(SEC): 0
[23] WARM_UPS: 255
[24] CLR_DIST(km): 4457
[27] CAT_TEMP11(Deg C): 28.4
[28] VPWR(V): 12.305
[30] EQ_RAT: 0.999
[31] TP_R(%): 13.3
[32] TP_B(%): 22.7
[33] TP_D(%): 31.8
[34] TP_E(%): 20.8
Engine Off
[14] TP(%): 90.2
[31] TP_R(%): 81.2
[32] TP_B(%): 90.6
[33] TP_D(%): 78.0
[34] TP_E(%): 67.1
2024_11_11: 185,018km
** 13,995km since THROTTLE BODY CLEANING plus IAT & MAF CLEANING **
JDIAG 906S
[1] DTC_CTN: 0
[2] FUEL SYSA: CL
[3] FUEL SYSB: —
[4] LOAD_PTC(%): 23.1
[5] ECT (Deg C): 93, Cycles from 92 to 100 Deg C. Fans run for 30 Seconds drops back to 92 Deg C
[6] SHRTFT1(%): 0.8
[8] MAP(kPa): 31.0
[9] RPM: 651
[10] VSS(km/H): 0
[11] SPARKADV(Deg C): 8.5
[12] IAT(Deg C): 42
[13] MAF(g/s): 1.52
[14] TP(%): 11.4
[18] OBDSUP: EAOBD
[19] RunTM(SEC): 459
[23] WARM_UPS: 255
[24] CLR_DIST(km): 4490
[26] O2S11(mA): - 0.008
[27] CAT_TEMP11(Deg C): 427.8
[28] VPWR(V): 13.801
[29] LOAD_ABS(%): 16.5
[30] EQ_RAT: 1.004
[31] TP_R(%): 2.4
[32] TP_B(%): 11.4
[33] TP_D(%): 31.8
[34] TP_E(%): 20.4
[35] TAC_PCT(%): 2.7
Rob
