Mazda 2 bearing noise.
Old Oct 25, 2024 | 07:15 AM
Arthur.m's Avatar
Default Mazda 2 bearing noise.
My 2010, 140k has a bearing noise, mostly on left hand steering, thought it was the wheel bearing but it and the other 3 are smooth, so I'm thinking could it be the diff bearings, I'm getting a little noise with on right hand steering and straight line. Any one gave any knowledge of this issue.?
Old Oct 25, 2024 | 08:55 AM
Old Oct 27, 2024 | 05:06 AM
I would use a stethoscope to listen carefully to each wheel bearing while someone else spins the wheel as fast as they can.
Old Oct 27, 2024 | 09:46 AM
Have you ever used an inexpensive db meter. It works as well plus you can actually see the failing bearing represented in a erratic or higher bb then comparing the other bearings.
I use it occasionally now after getting to try FORDs specialized sound locator they have for tracing unusual sounds from a specific model that was higher on the list of noise complaints from owners.
About the only downfall is like the other sound hearing aids you need to know what a functional part sound like vs one that is only starting to go bad. Unless naturally it is just an obvious bad noise.
Karen Martin
May 27, 2019 12:55 PM
hall.tristanj
Feb 13, 2017 04:23 AM
exodave
Jan 19, 2015 07:28 AM
Alister
Oct 12, 2010 06:51 PM
MzdaP5
Jul 25, 2007 04:16 PM
