Glow plug light blinking non stop
Old May 6, 2023 | 03:33 AM
J0mata's Avatar
Default Glow plug light blinking non stop
Mazda 2 2016 1.5 Diesel AWD Automatic, glow plug light blinking non-stop.
Connected a scanner and it aknowledges de light blinking, but no DTC showing up. Car starts normally, no problems
Where should I look and what can it mean?
How to stop that light to keep blinking?
Thank you.
Old May 6, 2023 | 09:32 AM
When was the oil & filter last changed? When was the oil data last reset?
Old May 6, 2023 | 11:44 PM
J0mata's Avatar
Oil and filter were changed last November and car has run 1016KM since then. Very little usage. Yes, the oil data was reset.
Running the scanner it shows 2 fault codes in the PCM - P2459:00-2F - Particulate filter regeneration Frequency (Bank 1) - Continuous MemoryDTC.
However, scanning for DPF regeneration it shows:
Distance Between Diesel Particulate Filter Regeneration 9(km) - 34km
Distance Since Last DPF Regeneration(km) - 61.8km
Distance Since Last Oil Change(km) - 1016km
DPF Indicator Illumination Count - 0
Checking for the glow plug , it shows:
Glow Plug Lamp - ON/OFF alternating
Glow Plug Voltage(V) - 0V
I am at complete loss.
I am in Timor-Leste, no Mazda dealer.
Any help would be very much appreciated.
Regards
Old May 10, 2023 | 12:23 PM
ganthercage's Avatar
it might be a fuse problem
Old Sep 24, 2024 | 07:47 AM
gSofos's Avatar
Hello. Have you managed to sort it out. Have the same exact issue!!
Old Feb 19, 2025 | 06:59 AM
Thatmazda2's Avatar
Default Same problem
I have the same indicator blinking. I had the car since 2019 and last November I had it blinkig for the first time. We did a dpf cleaning on a machine. It seems to come up again. Any one who solved this?
tonyb760
Mar 16, 2026 11:06 PM
petegeoff
Apr 18, 2018 09:12 AM
aliceearth
May 15, 2008 03:54 PM
DWasserboehr
Sep 16, 2007 02:39 PM
cugene
May 21, 2007 11:00 PM
