Flashing Wrench Light
Hi All,
So I have a Mazda 2 2015 Diesel. The wrench light just began blinking a few days ago.
From the manual it stats " When flashing (SKYACTIV-D 1.5, SKYACTIV-D 2.2)
The sedimentor separates water from the fuel.
If water accumulates in this filter, the warning light will flash. When it does, consult an expert repairer, we recommend an Authorised Mazda Repairer as soon as possible."
Question is, where is the fuel filter located in the diesel models. I have looked for it everywhere in the bonnet. N.B it's not behind the battery like other models.
Any help?
Any help?
Hi grim-reaper
Thank you for the response. So I checked around the fuel tank under the car. Still have not found the filter.
Not sure why Mazda decided to make this so difficult
PROBLEM SOLVED,
So I took the car to the garage. We ran the diagnostics and everything was fine. He then just reset the "Sedimentary Service" and the flashing Logo disappeared
It will come again every 20,000km's just to remind you to drain the water from the diesel filter.
Did you happen to notice how old this thread is?
You may notice that "tony" last log in was Last Activity: Aug 24, 2022 11:17 AM
He may not respond.
But maybe some other member might have an answer for you?
He may not respond.
