Err message
I have the err message on my radio after inputting 3 wrong codes in. I can get the radio to go back to giving me the option to input another code, but I don't know where I can get the correct code. Please help :)
Contact your local Mazda dealership
I found this searching around (you might need to substitute Preset 6 for 'SEARCH': Also try codes: 3511,1414.
If you know the Owner"s Code, a four-digit code, the instructions are fairly simple: STEP 1: Turn the ignition to ACC STEP 2: Briefly and simultaneously press both SEARCH and AUTO-M. This action should change the display from a blinking code to a solid . STEP 3: Using the radio preset buttons 1, 2, 3, and 4, set the Owner"s Code in the display. The first position can be set using the 1 button, the second using the 2 button, etc. STEP 4: Press and hold both SEARCH and AUTO-M until you hear a loud beep and the display shows good. The radio will then turn off, and you are ready to start listening again. If you don"t know the Owner"s Code, the instructions are similar. The first goal is to get the display to flash"ERR" instead of code. Then you can enter the Dealer Code to reset the radio. Here are the steps: STEP 1: Turn the ignition to ACC STEP 2: Briefly and simultaneously press both SEARCH and AUTO-M. This action should change the display from a blinking code to a solid. STEP 3: Using the radio preset buttons 1, 2, 3, and 4, set any four-digit code in the display. The first position can be set using the 1 button, the second using the 2 button, etc. STEP 4: Press and hold both SEARCH and AUTO-M. If by some chance you guessed the Owner"s Code, there will be a loud beep and the display will show good before the radio turns off. If this happens, you are done. More likely, the display will briefly show"ERR" and then change back to the flashing code. STEP 5: Repeat steps 1-4 until you have a flashingERR instead of a flashing code. STEP 6: Press the following buttons in sequence: SEARCH, AM, AUTO-M, FM 1/2. The display should now show . STEP 7: Set the code to 4989 using the preset buttons, as before. Press and hold both SEARCH and AUTO-M until you hear a loud beep and the displayflashes good. The radio will then turn off, and you are ready to start listening again. This will speed you on your way to getting your radio back! |
Hello, my Mazda Tribute 2009 has no AUTO-M Button. How can I fix the ERR code? Thank you in advance for your help.
