2004 Mazda 2 Sport ODB II Error Codes
p { margin-bottom: 0.1in; direction: ltr; color: rgb(0, 0, 0); line-height: 120%; }p.western { font-family: "Liberation Serif","Times New Roman",serif; font-size: 12pt; }p.cjk { font-family: "WenQuanYi Micro Hei"; font-size: 12pt; }p.ctl { font-family: "Lohit Devanagari"; font-size: 12pt; } Hello All,
I have a 2004 Mazda 2/Demio with about 45000 miles on it. Using the Maxiscan MS309 ODB II/EODB reader for diagnostics, I get the following 8 error messages: 1/8: P0715 $07E8 Generic Input/Turbine Speed Sensor A circuit. 2/8: P0351 $07E8 Generic Ignition coil A primary/secondary circuit. 3/8: P0733 $07E8 Generic Gear 3 Incorrect Ratio. 4/8: P0841 $07E8 Generic Transmission fluid pressure sensor switch A circuit Range/Performance. 5/8: P0031 $07E8 Generic HO2S Heat Control Circuit Low Bank 1 Sensor 1. 6/8: P0351 $07E8pd Generic Ignition coil A primary/secondary circuit. 7/8: P0841 $07E8pd Generic Transmission fluid pressure sensor switch A circuit Range/Performance. 8/8: P0031 $07E8pd Generic HO2S Heat Control Circuit Low Bank 1 Sensor 1. So can anyone tell me what needs to be done, in terms of dealing with these errors? Much appreciated. Regards, Dan. |
1st thing is to try & clear all these codes, as you don't know how old or relevant they are.
If they come back then let us know. |
(Post 162198)
