After heavy rain my passenger side footwell is soaking wet I cannot find any cause of the leaks , Anyone!! any ideas please..
James Mazda Tribute 2002 by the way |
The very first thing to check is the drains at the bottom of the door. These little, often over looked things can cause a myriad of trouble in the wet footwell leak department. Be sure they are clear. After that, check the rocker panel drains too. Then, look for trouble in the windshield seal. Have you had (or a previous owner perhaps) a windshield glass replaced? |
Mazda passenger footwell leak
Thats great I will check the door n get back to you,,, where are the rocker drains located then please.
James |
Beneath, at the bottom of the rocker panel. They usually appear as bumps between the two panels (inner and outer rocker) where they come together. |
thank you!I suspected my rocker panels..i think the holders are broken..
Check the sunroof drains if you have a sunroof...
| All times are GMT -5. The time now is 02:39 AM. |
