Unidentified buzzing tone from dashboard
Old 09-18-2018, 03:49 AM
Johnnyh's Avatar
Default Unidentified buzzing tone from dashboard
I've an 04 tribute that has started emitting a buzzer/tone sound from the dash completely at random, I've read forums that mention a set of five tones but this is a continuous sound. There are no warning lights that accompany it and it stops when I tap the break pedal (not actually activate the break). Has anyone come across this before, I've read through the whole manual and as far as it's concerned no such sound should exist
​exit. Any advice appreciated
Old 09-18-2018, 06:45 AM
Sounds like it could be a leaking brake booster.
Old 09-18-2018, 09:41 PM
simonsi's Avatar
As in an electric buzzer? The booster was more of a hiss from the air flow, or at least mine was...
Old 09-18-2018, 11:18 PM
Johnnyh's Avatar
Yes it's a high pitched electronic buzz. Definitely an alarm of some kind but to what I can't figure.
Old 09-19-2018, 07:06 AM
Does it make the noise when the ignition is on? or only when the engine is running? Disconnect & block the vacuum line to the brake booster to eliminate it as the cause of the noise.
Old 09-26-2018, 12:45 AM
Cliff_Yu's Avatar
Is this your first hand car or 2nd hand car? Quite often previous car owner added some device which triggers the buzz.
Old 12-31-2018, 09:23 AM
Jean-Max Rigaud's Avatar
three 5 seconds intervals, with 5 buzz, right?
norcek
01-30-2017 06:34 AM
packjed1
07-08-2013 04:34 PM
jgibso
05-22-2006 10:16 PM
TipTronic3
08-15-2005 04:41 AM
Quick Reply: Unidentified buzzing tone from dashboard
