Tune up advice
I'm about to do my first tune up in a long time. I used Bosch +4 plugs last time but I've since read that they eat through coils. So this time I want to get some quality stuff that are durable.
What spark plugs and ignition coil manufactures do you all recommend. Jaysen 2002 Tribute ES |
NGK plugs.
(Post 139565)
NGK plugs.
Should you change the coil as well as the spark plugs or does it matter if you only change the spark plugs?
Originally Posted by Sullavance
(Post 142320)
It is quite confused.
Depending on your mileage. Some people like to wait to change there ignition coils. The cons of this are: when misfiring ocurrs you are sending raw fuel to catalytic converter which could melt the cat. Also another person recently posted that their faulty ign coil caused the pcm to fail, so now he's looking for a new pcm as well. How often do you change plugs, how many miles since the last change? Have you ever changed your ign coils? If you change plugs every 60,000 miles, put on new ign coils. I did.Clean the egr, throttle body, maf, change the pcv valve. |
I buy all my parts from Rockauto. Save a bunch of money.
Originally Posted by kuzindwight
(Post 139562)
