Trouble Code P0101 back again
3 Attachment(s)
:mad: YES it`s back again CEL light came on today after 600miles. Checked codes and it showed P0101:mad:
(There is also a rattling, tapping noise from under the front engine cover) After changing the MAF sensor, a new Air Filter, cleaning AIC valve and replacing silicone vacuum pipes it is back even after resetting the EEC. I have added both of these to the fuel tankAttachment 2257 this first Attachment 2258 and then this and I still have this to spray into the Air Intake downstream of the MAF to do a engine de-coke Attachment 2259 The only thing that I have not cleaned yet is the Throttle Body as this Power Boost may do that:( Is there anything else that I have overlooked or forgotten to DO or clean? Please Guys as this problem is putting me on the verge of selling off this dam Son Of A B**ch Mazda Tribute:mad: |
Whats the history on the maf sensor? I'd suggest if it is "new" remove the electrical plug, using a non conductive electrical contact cleaner, clean the connectors throughley
The MAF sensor is 2 months old, it`s a Delphi from Rock-Auto.com
I will use some Servol 10 electrical contact cleaner on the connectors tomorrow and hope that it fixes the problem - Thanks Kevinkpk |
Is this the only code?
Originally Posted by Kevinkpk
(Post 139892)
The noise could be something different. That code dictates to me a MAF sensor sine wave out of tolerence within idle. Is the (I know ) air intake "intake/unmodified?
(Post 139896)
Originally Posted by turboturney
(Post 139915)
Yes Unmodified BUT clip loose on concertina hose air intake end, tight on throttle body end:o
