2009 Tribute with charging issues
Old 04-12-2018, 06:52 PM
bm1082000's Avatar
Default 2009 Tribute with charging issues
I have a rather unique charging issue here. Trying to avoid the dealership at all costs lol. So this 2009 Tribute Charges fine for 60 seconds. Alternator puts out 14.8 volts steady. After one minute the rpm drop by about 500 and the voltage drops to 8.4 volts. If you turn the engine off then crank it back up it does the same thing again, after exactly one minute. I've replaced the alternator three times and the battery once. I've checked every ground connection and every fuse. I've traced the battery cables in hopes of finding a fusible link with no luck. I really hoping it's not the pcm. It's a 2009 Tribute S with a 3.0. Any help would be greatly appreciated.
Old 04-15-2018, 02:53 AM
simonsi's Avatar
What is your battery voltage, engine off?
8.4V either indicates a massive drain (like more than starting current) or a failed battery with the alt offline. Even if you have already replaced it, I'd start with the check above.
Assume its <not> a hybrid?
rubenreyes
01-12-2017 09:42 AM
backyardmechanic
12-09-2009 06:23 PM
92dxer
05-19-2006 11:44 PM
syncrait
02-23-2006 08:40 PM
Davis
07-31-2005 01:17 AM
Quick Reply: 2009 Tribute with charging issues
