Spark Plugs
:) Well any recomendations on a Good brand Spark plug for my 2002 Tribute V6, other than stock. Or is that the best all around plug recomended.
RE: Spark Plugs
NGK plugs are good, it would be nice to here if Babyhuey had any thoughts on this .
RE: Spark Plugs
stock would just fine but you could also use double platinum Autolites, they are very close to motorcrafts.
RE: Spark Plugs
I'm a fan of NGK plugs. Never had a problem with them
RE: Spark Plugs
They are spark plugs...just use the stock platinum ones. They go for 100k miles, what else can one ask for? ;)
-a |
RE: Spark Plugs
Anyone know what the stock spark plug is?? Number on plug?? I am having a really bad shimmy and loss of power to my 01 tribby (a/c craps out) engine light on. Code saying the Main and Secondary Coil maybe faulty. Took my girl in for a check up to a local auto shop and hejust told me to buy new plugs and wires and hopfully that will fix this problem. I will be putting this in another part of this forum later...
Thanks |
RE: Spark Plugs
These NGK plugs are good and you can get them @ NAPA/UAP
http://www.napaonline.com/images/u_clear.gifSpark Plug[/b] http://www.napaonline.com/images/u_clear.gif http://partimages2.genpt.com/partimages/310496.jpg Click on image to see enlarged view http://www.napaonline.com/images/u_clear.gif Bottom Front function ViewImage() { var imgSrc = (document.getElementById('PartImage')).src; var newWindow = openWin(imgSrc, 'popup_win', 'width=450, height=450,toolbar=0, location=0,directories=0,status=0,menuBar=0,scroll Bars=0,resizable=1'); newWindow.focus(); } function SetImage(obj) { var imgUrl = obj.options[obj.selectedIndex].value; var imgTag = document.getElementById('PartImage'); imgTag.src = imgUrl; } http://www.napaonline.com/images/u_clear.gif Item#: NGK3951 http://www.napaonline.com/images/u_clear.gif http://www.napaonline.com/images/u_clear.gif Attributes: Features & Benefits:"V-grooved center electrode offers lowers ignition system voltage better ignitability increase fuel economy lower emissions increased anti-fouling characteristics" Thread Size:14mm Hex Size:5/8" Reach Length:.708" Seat Type:tapered |
