Rear rotor and brake pad replacement on 2006 Tribute?
I have done plenty of front rotor and brake pads on several cars in the past.
According to my mechanic, the rear shouldn't be that much different from the front since the e-brake is in the hub. My question is that some cars use a special rotating tool with two pins to reset the piston instead of the basic c-clamp we are all use to. Does Mazda Tributes require this tool? I know for fact GM's use it. The reason I ask is because I don't have this special tool which is a round plate with two pins that connect the two pin holes in the caliper piston. It actually rotates the piston as the clamp screws the piston to its reset position. |
I have read somewhere that you may be able to use a pair of needle-nose pliers for the job. I have not had a need to do that myself.
Nevermind, I called my mechanic and he said the Ford Escapes and Madza Tributes require no special tool to reset the piston.
The "C-clamp" will be fine just like the fronts. |
| All times are GMT -5. The time now is 01:23 AM. |
