2008 tribute v6 cd4e transmission problems
i have a 2008 tribute with a v6 fwd and a cd4e transmission. First problem after driving probably 3 miles it seamed like it forgot where the gears where. Going in and out of gear, the rpms goung up some and 2 warning lughts came on, the wrench and the check engine. After getting home the code reader gave the code, P0741. The transmission fluid smelled burnt. I replaced the fluid and the solenoid pack because it only registered 6 ohms when i tested it. After replacing i adjusted the neutral safety switch and for a minute it ran ok, untul it got warm or got above around 25 mph rhen rhe same problem was back. What do i do now?
Yep - as per my first answer you are probably looking at a replacement or rebuilt trans. I'd be taking it to a specialist for comment and confirmation but the burnt fluid and the symptoms not responding to the solenoid pack change seem pretty clear.
These are not a real strong trans from what I have read I replaced mine at easter with a second hand unit it was all up supplied and fitted $2000 as I cannot do that sort of work anymore a rebuilt was going to cost over $3500 and it is more or about the same as the car is worth, I was very disappointed to discover that they have had gearbox problems after buying ours 3 years ago now know why they are cheaper than comparable sized cars around here
Herblenny
01-14-2008 08:53 AM
