P0193,P0453,P0108,P0123 all showing on a 2006 2.3L Tribute
Hi I have a 2006 2.3L Tribute. Sitting at stop lights the other night it revved up really high. Check engine light came on with these codes? No issues until the other night. Is it my throttle position sensor, bad fuel pump or bad fuel pressure sensor P0193,P0453,P0108,P0123.
Since they all showed up at the same time I would be looking at the connector to the ECM. These sensors all connect to the ECM. Maybe you had moisture getting into the connector or the wiring harness shorted out.
It is much less likely that each sensor failed at the same time. Also, just for the heck of it, test the battery and the alternator. Voltage spikes or drops could throw the computer for a loop. |
thanks I was wondering that thought it was weird that they all showed up like that? I was like cannot be all those issues in one shot. Should I just unplug ECM connector clean it with electrical contact cleaner see what happens? It's a new battery last fall but the alternator was changed in Feb? I will get them both checked again. Thanks
Disconnect, inspect, clean and reconnect. That's what I would do first. Disconnect the battery first.
While you are at it check and clean ground connections. |
