-   Mazda Tribute (https://www.mazdaforum.com/forum/mazda-tribute-22/)
-   -   p0128 trouble code (https://www.mazdaforum.com/forum/mazda-tribute-22/p0128-trouble-code-35317/)
erik2282 Apr 30, 2015 01:24 PM
p0128 trouble code
'06 Tribute
4-cylinder
169,000 miles
Got this code. I checked the reservoir, it was almost dry so I added water to it to bring it up. Then I drove it around and MIL was still on so I disconnect battery to clear code. Two days later the light came back on with same code.
Should I change the ETC sensor, or flush the coolant system and replace thermostat? Also I read about some programming or calibrating thing? Anyone have any suggestions?
Thanks
erik2282 May 3, 2015 07:12 AM
I changed the Thermostat and fluid yesterday. I disconnected battery to clear code. This morning light is back on. errr. Will go to auto parts today to get code read to see if its the same, or maybe i left something disconnected, dont think so though. If its still P0128, then I'll buy a new ETC sensor.
erik2282 May 3, 2015 11:22 AM
Got code read. P0193 (fuel rail pressure something-or-other). I guess I did leave something disconnected. I hope I didnt damage any wire/connectors. I will check it out today.
At least no coolant code..
erik2282 May 3, 2015 02:05 PM
I'm having a conversation with my self here.. lol
I checked and there was no loose connections, I reseated them all. I disconnected the fuel rail sensor and cleaned it with carburetor cleaner. Took it for a test drive and the light hasn't come back on. I'll wait a couple more drive cycles and see if it stays off. Crossing fingers...
erik2282 May 5, 2015 10:08 PM
light still off. changing thermostat and coolant worked.
:o
UseYourNoggin May 6, 2015 07:45 AM
Lots of mileage, could be anything, would have been nice to know last time coolant and thermostat changed, still may have to chaange coolant sensor as that may be full of crud.
erik2282 May 6, 2015 11:10 AM
Thank you for your comment. Coolant was flushed at about 100K miles. I cleaned sensor, still looked ok. If light turns on again, then I'll change sensor.
