noise front tire driver side
i have 100.000 miles on the tribute i am noticing a loud noice in the front driver side,not sure what to look for i am going to remove the tire and check if i can see anything. would it be the bearing, if it is would i be able to notice anything or feel any movment anywhere? any suggestions on what it could be
thanks |
Check the sway bar links.
if it is a constant hum, it is probably the wheel bearing or hub, depending on the set-up.
