Gaskets
I am doing a valve replacement job and as you know I will have to buy bolts and gaskets, in your opinion what brand should I use. and if you can refer me to a supplier would be great. Thank you.
Originally Posted by Jaimjer
(Post 148838)
2.0L Zetec bored out to 2.2L, home from the shop and ready to get started!
http://i133.photobucket.com/albums/q...psf307e271.jpg Let the fun begin! |
New 4 - 1 header.
http://i133.photobucket.com/albums/q...ps2462e343.jpg New Intake manifold, individual throttles and header mocked up to ensure that this beast will fit in the engine bay. http://i133.photobucket.com/albums/q...ps88cdf63c.jpg Will be a snug fit, however I do not foresee any issues. |
Ended up pluming up the remote oil filter lines today.
I reused the original aluminum power steering cooling lines...... Figured if I was deleting PS might as well use the lines for something. Got to keep on budget...lol http://i133.photobucket.com/albums/q...psafe5061b.gif http://i133.photobucket.com/albums/q...ps50c029a4.gif http://i133.photobucket.com/albums/q...ps04a3a6b6.gif I will be keeping the stock Escape/Tribute oil cooler/heater on this setup as well. I plan on running it at the remote filter location rather than at the block. That way any temp differential from running aluminum lines will be evened out. |
Another step closer this weekend! Test fit of the serpentine belt with the A/C compressor removed, Bostig Power Steering delete kit and CFM Uner Drive Crank Pulley installed........ Threw in a new water pump and tension pulley as well.
http://i133.photobucket.com/albums/q...psad3e5f4f.jpg Timing belt is on it's way......... Then I have to wait for someone to shovel the 8.5' of snow off the Tribute....lol |
