Mazda Tribute doesn't want to run
Hi guys. First time here. I was hoping I could get some help as I've never encountered this problem. I have a 2002 Mazda Tribute that I lost my only key for about a week ago, I wasn't experiencing any problems with it prior to this. I went to Mazda, had them cut me a service key with no chip so I could put in neutral and move it around. Two days ago I had a locksmith come out and program me two keys. Worked fine til I got 30 minutes from house and stopped at bank. Turned off and came back out wouldn't start. It wasn't allowing me to move the gear selector into any gear either(that's weird part; figured it couldn't be starter for that reason). So I had it towed home.
I ended up killing the battery trying to figure it out. So I put a battery charger on. When I put the negative on I noticed the connector was bad. Replaced it with a new one. Car started right up. Told myself no way is it that simple; it's never simple or easy. Went for a quick drive. It died right when I parked and wouldn't allow me to put back into gear like before. So what I know New negative connector New keys - car light with key comes on but turns off when I try to turn key, don't believe this is issue Starter is still good Seems to be an issue before it If you need any more information ask and I'll respond asap. |
Also forgot to mention computer is not throwing any codes.
