Fuel pressure problem
Old Oct 27, 2021 | 10:11 AM
Bobsyouruncle's Avatar
Unhappy Fuel pressure problem
My system holds pressure throughout the day, but loses pressure over night. I've changed the the regulator and the fuel pump but still loses pressure over night. (no codes) I prime the system and it starts. Where do I go from here?
Old Oct 27, 2021 | 07:43 PM
ipn's Avatar
ipn
By explaining what engine/Year
Old Oct 28, 2021 | 08:20 AM
2001 Mazda Tribute 3.0 V6
Old Oct 28, 2021 | 09:12 PM
ipn's Avatar
ipn
I'd not worry about it unless there is a problem with actually starting the engine , but the most likely thing is one or more than one injector is weeping under pressure over a long time during the hot/cold cycle or the o'rings are weeping slightly on the rail , those injectors can be expensive hence if that is the only thing happening i'd let it slide until things got worse :-) (i'm poor) , but it might just be a o'ring which are cheap .
good luck
Old Oct 29, 2021 | 12:28 PM
Pressure was cut off from the regulator to the injectors and let to sit over night. Pressure from the regulator to the pump went down. All points to the fuel pump so I changed to a new one. Still have a pressure leak with no codes.
cncman40
Jul 16, 2020 12:47 AM
keenyoung
Aug 4, 2013 05:26 PM
Ronny64
May 13, 2012 07:30 AM
wicked_breaks
Jun 22, 2007 08:17 AM
