Front and Rear windw washer fluid won't come out
Mine is 2005 Mazda Tribute and I have not done any maintenance check up for last 2 years.
Today while I was driving (the weather was cold) I wanted to wipe out some dirt on both front and reat window, so I turned the switch but only to find out nothing is coming out from rear window and just few sprays of icy fluid came out of front window. I thought there must be low level of the washer fluid, so I bought a new one and filled her up and treid again but nothing comes out this time. Wipers are working fine, but just the spray is not coming out. Is the nozzle possibly frozen or clogged? Or do I need to buy whole new washer pump in order to make it work again, Or is it covered within the warranty (the mileage is 85000km). Your answer will be greatly appreciated. |
RE: Front and Rear windw washer fluid won't come out
Mine was doing the same. Turns out it was the rubber hose from the washer fluid reservoir. It had slipped off a connector and all the fluid was just coming out on the ground under the vehicle. It easy to remove the fender liner from the R front wheel well. The reservoir, pump, and supply lines are all easily visible and its easy to fix a leak.
