Door Ajar light - 2006 Mazda Tribute
Old Feb 21, 2016 | 07:44 PM
rman487's Avatar
Default Door Ajar light - 2006 Mazda Tribute
All,
I have a bit of an annoying problem; the door ajar light keeps poping up while I drive, and then goes away. I've tested all the solenoid valves on each door by cycling them open/closed, but I can't get the light to go off in the first place to test where in the system the problem lies. Does anyone have tips on where to look? The Haynes manual doesn't really provide a lot of detail other than the wiring diagram.
Old Aug 28, 2016 | 07:51 PM
tonyk77's Avatar
i am having the same issue, my mech says its the door lock actuator, mazda wants 200 for the part but u can find it online, prob im having right now is where is it in the door to switch it out.
Old Aug 30, 2016 | 12:00 PM
rman487's Avatar
Interesting, are you able to lock your doors?
Old Aug 30, 2016 | 08:41 PM
tonyk77's Avatar
the driver side door i have to do manually, the others work when i hit the lock button on the remote and door
Old Jul 1, 2022 | 03:41 PM
mobiletech's Avatar
Default I fixed this is
[QUOTE=rman487;156658]All,
I have a bit of an annoying problem; the door ajar light keeps poping up while I drive, and then goes away. I've tested all the solenoid valves on each door by cycling them open/closed, but I can't get the light to go off in the first place to test where in the system the problem lies. Does anyone have tips on where to look? The Haynes manual doesn't really provide a lot of detail other than the wiring diagram.[/QUOTE}
cut the pink and light blue and the black and white wire make sure u splice them togther and use electrical tape it will fix ur issue
angelito584
Apr 24, 2025 07:45 AM
Johnr863
Dec 31, 2015 10:52 AM
qtband
Dec 5, 2011 03:52 PM
Hoosier56
Feb 20, 2009 09:05 AM
tygel14
Oct 3, 2006 04:03 PM
