damp footwell 2001 tribute
Hi all
my 2001 tribute has got a damp drivers side (rhd car) footwell anyone else had or heard of this problem and have any pointers of where to look before i start stripping the whole car down to fix it Thanks Rob |
There are three usual things that cause this: 1) The heater box drain is clogged, missing or disconnected (A/C condensation.) 2) The drain holes in the bottom of the door(s) are clogged with filth, rust and debris. 3) The sunroof/moonroof drains are clogged and/or disconnected. Beyond that I can think of any cowl drain that may be clogged allowing water to back up into the interior. |
Rear screen wash pipe could be leaking from in driver foot well.
It has a joint in there check this. |
If you have a moon roof it is most likely the drain line is clogged. There is one on each side that runs down thru the windshield post. If you have a compressor you can blow them out with about 100 psi from the top.
If you have had a front screen replaced i have had a leak from this and had to have it re installed as it was not sealed well enough
| All times are GMT -5. The time now is 02:36 AM. |
