AC leak
Old 05-29-2007, 08:34 PM
grytrib's Avatar
Default AC leak
My 02 tribute is leaking water on the passenger side front floorboard under the glove box. Someone mentioned there is an underbody valve that clogs and just needs to be drained. Does anyone know where the valve is and what it looks like?
Old 06-01-2007, 03:14 PM
babyhuey's Avatar
Default RE: AC leak
The A/C evaporator drain is just a short 1" pipe sticking out of the firewall in the engine compartment on the passenger side. If you locate where the A/C pipes go thru the firewall in the right rear corner of the enginge compartment then just look down about 10 inches and you will see the little pipe protruding out.
Rjeter
04-01-2011 08:44 PM
austintitus3
12-29-2006 02:59 PM
terribletodd
02-15-2006 10:38 PM
crmx0312
01-16-2006 08:14 PM
Alucard
01-05-2006 04:45 AM
Quick Reply: AC leak
