2005 Mazda Tribute Radio Swap
I am struggling to swap a radio into a tribute i have. I have found multiple wiring diagrams but some say different things. I am pretty sure i figured out which were the speakers as all diagrams had those listed as the same but cant figure out which wires are ground, acc, and power. the diagrams i found show the black/green wire as power but if i use a multimeter it shows nothing but i noticed if i use that as a ground the orange/green wire shows constant 12v with the car off but none of the wires give me 12v with the keys at acc? im so damn confused and have never had this much of a problem with a radio swap.
idk if the radio i have is bad or what but does anyone here have a proper wiring diagram for an 2005 tribute before i drive this thing into a wall? |
Black only wire is normally the common earth , so muti-m earth lead on black and probe the other wires , you might have it sorted out by now though , good luck .
Just for extra info a 2003 year . 2003 Ford Escape Car Audio Wiring Diagram Radio Battery Constant 12v+ Wire: Orange/Light Green Radio Accessory Switched 12v+ Wire: Yellow/Black Radio Ground Wire: Black Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Left Rear Speaker Positive Wire (+): Tan/Yellow Left Rear Speaker Negative Wire (-): Gray/Light Blue Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink |
| All times are GMT -5. The time now is 08:21 AM. |
