2003 Tribute tail light assembly
Does anyone know how easy/difficult it is to remove and replace the tail light assembly on a 2003 Mazda Tribute? I have a replacement tail light ordered and would like to replace it myself. Thanks.
RE: 2003 Tribute tail light assembly
Super easy to replace golfen. All you need is #2 phillips screwdriver and plastic flat prying tool onlong with about 2 minutes of your time.
[IMG]local://upfiles/1377/4A381BFE699C4F6EA724D22E24991B49.jpg[/IMG] Start by removing these two #2 phillips screws. [IMG]local://upfiles/1377/E8927D44A3DE4D91B1AE495244AF6848.jpg[/IMG] Now you need to insert a pry tool here between the sheet metal and taillight body. An inexpensive plastic putty knife works well or just wrap the tip of a flat screwdriver with tape so you do not damage the paint where you are prying. [IMG]local://upfiles/1377/D9BFD663355C471E9DE5DBEC28891AB3.jpg[/IMG] These are the two little nubs that are holding the outer edge of taillamp to vehicle body so you can see what you are trying to pry loose. [IMG]local://upfiles/1377/1646251FA2F345FB8CF3DD284EC6C33E.jpg[/IMG] Here is a pic of the two plastic grommets that the taillamp nubs press into. Unclip the bulb connectors and you are ready to install the new one. |
Thanks so much for the quick reply, I really appreciate it and the info!!
Mike |
Originally Posted by babyhuey
(Post 33393)
