-   Mazda Tribute (https://www.mazdaforum.com/forum/mazda-tribute-22/)
-   -   2002 Mazda Tribute Viper 350 Plus door lock problem (https://www.mazdaforum.com/forum/mazda-tribute-22/2002-mazda-tribute-viper-350-plus-door-lock-problem-30105/)
Tae Sep 23, 2012 08:14 PM
I've just finished (well almost) a Viper 350 plus alarm and I have one issue. The doors do not lock. Everything else works.
The problem is I can't figure out where to put the wires for the door harness.
2002 Mazda Tribute Car Alarm Wiring Diagram
I was using this site as a reference and it looks like I'm suppose to use the pink/white wire for both the unlock and lock on the door harness for the Viper alarm.
Power Door Lock Negative Wire (-): Pink/White (1-Wire Door Lock System). Lock requires a (-) negative through a 1,000 ohm resistor. Unlock requires a straight (-) negative, some units will require 2 extra relays.
Power Door Lock Negative Wire Location: In Drivers Kick Panel
Power Door Unlock Negative Wire (-): Same Wire As Above
Power Door Unlock Negative Wire Location: N/A
http://www.directeddealers.com/manua...426V_07-04.pdf
Page 10 shows the door harness diagram, it's basically two wires...blue and green.
Green (-) Lock, (+) Unlock Output
Empty Unless Using 451M
Blue (-) Unlock, (+) Lock Output
I've tried connecting both the green and blue from the Viper to the pink/white wire and this causes both buttons to lock. I see that I'm suppose to use a 1000 ohm resistor for the lock but is it suppose to be connected to the pink/white wire? blue and green (with 1000 ohm resistor) to pink/white?
