2002 Mazda Tribute surging while brakes are pressed
Old 04-24-2018, 05:13 AM
peedee's Avatar
There would be a pressure switch to boost the idle for more output at low revs
This is on the V6
Old 04-24-2018, 02:58 PM
simonsi's Avatar
This is on the V6
Thanks but I still dont understand the link to pressing the brake causing the surge via this switch???
Old 04-24-2018, 08:41 PM
peedee's Avatar
I tend to agree with you but mine started surging a month or so ago, I have checked and re gaped all plugs checked and re-plenished the electrical contact paste on each coil on plug, also checked wiring harness so might try disconnecting the plug and see what effect it has.
Old 04-25-2018, 12:05 AM
CrashOvahryde's Avatar
Sounds far-fetched - there are no switches on the 2002 power steering that I am aware of and no connection to anything that would make it surge.
What work did they bill you for?
Specifically for replacement of a power steering switch. Unfortunately, I'm not mechanically skilled so that's how it was explained to me by the mechanic and listed on the billing paperwork. Whatever it was resolved the surging issue but for all I know he could have just been trying to layman explain it.
Old 04-25-2018, 08:24 PM
peedee's Avatar
I do not think pressing the brake would actually have a reason to be the cause except where the vacuum booster is leaking then it would be lean all the time,
I think a faulty pressure switch would send a fluctuating signal to the idle control valve if it is the cause and mainly noticeable when stopped at light etc so coincides with brake pedal being pushed
Blackink
04-21-2015 06:23 AM
venpro
04-19-2011 05:45 PM
sjsmith801
06-25-2010 10:42 PM
mugatu109
01-31-2010 03:49 PM
di0nysus
08-11-2009 12:12 PM
Quick Reply: 2002 Mazda Tribute surging while brakes are pressed
