'05 Tribute Airbag light
Just an FYI.
I was getting a blinking Airbag light that blinks 4 times pauses then blinks 2 times and repeated this sequence several times then became steady. The first place to look is the sensor at the hood latch. After doing some other work, I for some reason did not have this connector connected properly. A simple disconnection and re-connection did the trick. I searched but could not find a guide to the airbag codes. Does anyone have a link that they could post to help out in case someone else needs a hand? '05 Tribute 2.3 4 cyl 140K+ '98 Protege 1.5 4 cyl 190k+ |
I also need the airbag codes. I receive 3-3 and there is no clear explanation of these airbag codes. Some say it is driver side pretensioner, others say passenger low resistance etc. If someone could share the airbag codes it would be very helpful to everyone.
