-   Mazda Tribute (https://www.mazdaforum.com/forum/mazda-tribute-22/)
-   -   04 Mazda Tribute Ignition Coil bolt (https://www.mazdaforum.com/forum/mazda-tribute-22/04-mazda-tribute-ignition-coil-bolt-28751/)
mayberry56 Mar 4, 2012 08:30 PM
Replacing plug coil. When backing the bolt out, I noticed I was not making any progress. I saw that the bolt housing was turning also. It is a brass fitting with teeth on the outside. I finally got it out and I guess it reamed it out pretty good. Now I cannot get the brass fitting to catch in the plastic housing.
Can I buy another brass fitting? If so, where?
Any suggestions will be appreciated?
Thanks
Phillip
MazdaTirol Mar 6, 2012 10:28 PM
Are the teeth on the brass bit still there? Is it the brass bushing that the bolt goes through in the coil plug?
gnoolygn Oct 1, 2021 09:31 PM
Hey there. I have the same problem. Do you remember how you fixed it? Where you got another brass fitting?
Thanks very much,
nadiamariyan@gmail.com
05_Tribute/Escape Dec 27, 2021 12:41 PM
You might be able to use 2 part epoxy to bind insert to valve cover
