Tires
it looks like the outside was more worn out and I got the allignment done and I think If I replace the front tires it should fix the problem,
Would It make a difference If I put different brand tires in front and keep the stock ones at the back, any suggestions |
RE: Tires
You can mix brands, but they will perform differently and may be slightly different sizes even though numerically they are the same (225/45R18). If the fronts and rears are the same size, I'd move the rears to the front and get new rear tires. I try not to mix brands.
