DSC / Traction Control on/off (non-owner question)
I'm considering an RX8 for my next car, so I've been doing a little research & reading your forums.
I wanted to know if the DSC / Traction Control can be turned off - I searched & found this post...
https://www.mazdaforum.com/m_39381/tm.htm
...so I'm 99% sure it can be disabled - does the switch turn off both components (DSC AND T/C)?
I would like to spend some time on the trackwith this car & I need to make sure I can disable the DSC & T/C.
Thanks!!
Franko
Thanks!!
Franko
Whoops - wrong post - I actually found a reference to the DSC on/off switch here...
https://www.mazdaforum.com/m_40258/tm.htm
Franko
Franko
Found the answer here:
http://rotaryinsider.com/rx8-42.html
You actually have to hold the DSC Off button for longer than 2 seconds (which causes a blinking error light on the dash) to disable ALL DSC features.
It's also apparently not advisable to disable DSC when you're accustomed to it keeping your fanny pointed in the right direction...
Franko
Franko
Yea... Definitly keep that nice quiet lil button ON when ur on the street... Unless ur used to drifting around a corner with ur groceries in the trunk.... My 8 is the 1st rear wheel drive CAR i have owend... If ur not familiar with its capabilities, itll OWN you....
