RX-7 Warning Light problem
I have 1991 RX-7 convertible, 76,000 miles,nice condition. It's my second car, so I only drive it about once a week. As I was driving to work this morning, the seat belt warninglight unexpectedly came on, followed by just about all of the other warning lights - battery, fuel, oil, washer fluid, etc. The car seemed to be running fine, but I immediately returned home. Is this an electrical problem or something else? I've had problems in the past with the battery draining, apparently because I don't drive it often enough. Is this problem related to that?
RE: RX-7 Warning Light problem
Could be alot of things. All that stuff runs through the CPU which is in the interior fuse block. You basicly have some tracing to do. Fuses/grounds/altenator/etc.
you may want to have the alternator and the battery checked to make sure the alternator is charging and the battery is holding the charge
ORIGINAL: trailermech78 you may want to have the alternator and the battery checked to make sure the alternator is charging and the battery is holding the charge |
Check to see if you have a broken alternator belt also.
| All times are GMT -5. The time now is 09:43 AM. |
