Clutch Problem
I have an 88' RX Conv. which i recently bought and the only problem i have with it is it will not let me (when the engines running) go into any gear, i was told a new clutch and throwout bearing were recently installed so i figured i would have no problems, any ideas???
RE: Clutch Problem
YOU NEED TO CHECK THE SLAVE UNIT & MASTER.
RE: Clutch Problem
Yea he is right you need to check th slave & master cylinders, has your pedal ever stuck to the floor, that is a common thing when they are going out. You can always buy rebuild kits for them rather than buying new ones you can get the kits for around 20.00 or so alot lot cheaper thatn buying new cylinders.
