Warning Sound for leaving the lights on
You know how you get that buzz when u left the lights on and switched off the engine?
I recently replaced my battery, which reset the computer in the car. It seems I have also lost that buzzing function. Is it caused by the reset? Is there a way to get that function back? Thanks! |
im not sure im just throwing this out but is it possible there is a fuse somewhere and when changing battery's it sparked and blew a fuse?
I dont have a quick fix, but... what car is this?
I am sure there is a great difference between '96 an '04 and also trim levels |
Does it ding when you open the door and leave the keys in it or just not keep the solid buzz for the lights? If its just the long one its gotta be a fuse, if both it could be the chime itself under the dash
It could be a loose screw in the switch on the Lower part of the B-pillar/door jam. Mine loosened up and now doesn't buzz. Might just be a coincidence when it happened? Just throwing it out there.
