Sunroof? Lubrication/maintenance?
My Protege has a sunroof and I've always been wondering...
Is there any kind of lubrication or maintenance that is required every once in a while? I don't want it to seize up, leak, etc... Thanks:) |
RE: Sunroof? Lubrication/maintenance?
If this is a factory sliding sunroof, there is usually little maintenance. The biggest thing is to keep the drain tubes clean from debris. Also keep the seals clean. You can use silicone spray for the seals to keep them soft. Just spray some on a rag and wipe the seals down.
Yeah, it's factory:) Cool... Thanks:)
hello i ahve a 1998 protege and the sunroof leak and i want to try to clean the drain how i can do this?
