stuttering when giving gas
have 95 protégé 1.5l was running good then started stuttering when giving it gas till dies. it idles great and in park can gently give gas and rev fine put when push down on gas quickly it starts stuttering till dies have changed plugs, wires, distributor cab and rotor, fuel filter nothing has helped it does act like starving for gas but is getting gas need help please
Hi john123:
This sounds like a bad air intake hose, or another vacuum leak. A vacuum leak messes up the reading by the MAF sensor. That makes the air to fuel ratio too lean and it misfires or dies. Take that air intake hose off and bend it to see if there are cracks in the rippled section. If so wrap it up tightly with duct tape and put it back. If you have an extra $60 or so buy a new hose. by the way, there is an "unofficial user's guide to the '95- 98 Mazda Protege". It's a sticky on the Protege forum. It's worth reading, but I am biased.;) |
I had recently put the new air intake hose on it but checked again it is good and vacuum seems good in all areas do you know what I should read on the mass air flow sensor but when I do leave unhook it will not start or wht I should read from throttle positioner it has a gas smell run idleing like running rich wich like you sad not mixing right
Could be not a hot enough spark ( ignition coil ) it should be a nice blue spark, not orange ).could be a bad fuel pressure regulator ( remove the vacuum hose and check for raw fuel ) It could be a bad MAF. [I]f you smell fuel then it is likely not the fuel pump. Bang on the cat converter to see if it came apart.
Did get a code reader it has 2 codes I can not find
P00FF C09B8 Any ideas thanks |
I checked the fuel pressure regulator the vacuum is good no gas in the vacuum side crimped the recirculation hose from it no different the Maf reads good and cars shut off when unplug it the cat conv is good the only other code besides above is P0335 which is crank sensor but that has been on for over a year and ran fine till now
Sounds like a bad coil. It is inside the distributor.
thanks the price is unreal though going to order one and see but i go over what i have checked just in case missing anything
changed wires changed plugs changed fuel filter change distributor cap and button took exhaust loose before cat checked vacuum all good checked air intake hose good checked MAF checked out good and cleaned checked TPS it checked out good crimped fuel return hose from to make sure kept pressure no change it will idle good can gently press gas will rev up fine that way but soon push as normal it just stutters checked spark at night to see better by using new plug and unplug gas injector ground plug crank spark does look orange till rev up then starts to turn bluish/white |
I got a remanufactured "Cordone" from RockAuto for a bout $250 if memory serves.
That's all I found on code P00FF: P00ff fuel air metering aux emission controls, I wish I knew what that means. I went through your list of things done/checked and did not see anything about the fuel injectors. Also check the spark by looking at the color, you want blue, not orange. |
you smell the gas pulled new plugs they are black now double checked spark it is orange found a new distributor on ebay for $90 the place has great feedback so buying one from there hope get it by this weekend thanks for everybody's help
